[Qgis-user] WMS-T printing issue
Frederick Löbig
frederick.loebig at grunsnid.de
Wed Oct 12 02:38:20 PDT 2011
Alright, thanks for your help. I will keep testing...
Best,
Freddy
B.Eng. Frederick Löbig
Röderichstraße 59
60489 Frankfurt am Main
E:: Frederick.Loebig at grunsnid.de
P: +49 (0) 69 - 78 99 52 41
M: +49 (0) 174 - 70 89 296
Office:
euNetworks GmbH
Ludwig-Landmann-Straße 40560486 Frankfurt am MainP: +49 (0) 69 - 90 554 - 534
E: Frederick.Loebig at eunetworks.com
S: floebig
This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
> Subject: Re: [Qgis-user] WMS-T printing issue
> From: giovanni.manghi at gmail.com
> To: bernhard.stroebl at jena.de
> Date: Tue, 11 Oct 2011 23:45:10 +0100
> CC: qgis-user at lists.osgeo.org; frederick.loebig at grunsnid.de
> Hi,
> > I have this combination: geoserver (2.0.2) with gwc and
> > 1) QGIS 1.7.0 on WinXP
> > 2) QGIS 1.7.1 on OpenSuse
> > I access the WMS server with tiled=true and get several tilesets to
> > choose from in QGIS. As you use CutePDF I assume you are on a Windows
> > platform.
> > Tests (MapComposer with only tiled WMS layer, A0):
> > 1)a) FreePDF: printing takes forever; killed after 40 minutes
> > 1)b) QGIS' pdf button, print as raster ticked: crashes QGIS
> > 2)a) print in pdf: works
> > 2)b) QGIS' pdf button, print as raster ticked: works
> > so problem confirmed for WinXP
> > To Giovanni's response:
> > QGIS 1.7 does not have the option named but the dev-branch (aka 1.8 in
> > OSGEO-Install) has
> > geoserver with gwc is not recognized as a tiled WMS when connecting to
> > it, so the "tilesets" tab stays greyed out, however if you append
> > tiled=true to the WMS-server's URL the tiles are offered. Maybe this is
> > different if you run tilecache on your WMS-server
> right, the option to set the tile size comes only in qgis-trunk.
> Do you have any public WMS url that can be used to make further tests?
> Cheers
> -- Giovanni --
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111012/63ce871e/attachment.html>
