[Qgis-user] WMS-T printing issue
Giovanni Manghi giovanni.manghi at gmail.com
Fri Oct 14 05:46:28 PDT 2011
Dear Bernhard and Frederick,
I finally found the time to make some tests.
I tested your servers on both Linux (4gb of system RAM) and Windows
Seven (2GB of system RAM, using a Virtual Machine).
The GWC one is correctly recognized as "tiled" (the layers are shown in
the "tilestes" tab) on both QGIS 1.7.1 and trunk.
I was able to create A0 PDF outputs, adding the "Luftbild" layer and
using the QGIS pdf printer (so I didn't used any external pdf printer).
I tested up to 300 dpi.
Under Windows with just 1GB of system RAM, when creating the A0 output
at 300dpi, qgis crashed, so it may be very well a memory problem.
I had no particular problems with the WMS server and the
"raster:jena_2008" layer, when printing to A0 at 300 dpi.
cheers
-- Giovanni --
PS
yes, at 300dpi/A0 it takes a lot (10 minutes or so) to create the PDF,
but it works.
On Wed, 2011-10-12 at 08:36 +0200, bernhard.stroebl at jena.de wrote:
> Dear Giovanni,
> I send you the URL of our WMS-Server in a personal mail as I do not want
> it to be in the list's archives forever
> these are the URLs I enter in QGIS
> WMS:
> GWC:
> The WMS-Server was solely set up to serve maps for our city map
> regards
> Bernhard
> Am 12.10.2011 00:45, schrieb Giovanni Manghi:
> > Hi,
> >> I have this combination: geoserver (2.0.2) with gwc and
> >> 1) QGIS 1.7.0 on WinXP
> >> 2) QGIS 1.7.1 on OpenSuse
> >> I access the WMS server with tiled=true and get several tilesets to
> >> choose from in QGIS. As you use CutePDF I assume you are on a Windows
> >> platform.
> >> Tests (MapComposer with only tiled WMS layer, A0):
> >> 1)a) FreePDF: printing takes forever; killed after 40 minutes
> >> 1)b) QGIS' pdf button, print as raster ticked: crashes QGIS
> >> 2)a) print in pdf: works
> >> 2)b) QGIS' pdf button, print as raster ticked: works
> >> so problem confirmed for WinXP
> >> To Giovanni's response:
> >> QGIS 1.7 does not have the option named but the dev-branch (aka 1.8 in
> >> OSGEO-Install) has
> >> geoserver with gwc is not recognized as a tiled WMS when connecting to
> >> it, so the "tilesets" tab stays greyed out, however if you append
> >> tiled=true to the WMS-server's URL the tiles are offered. Maybe this is
> >> different if you run tilecache on your WMS-server
> > right, the option to set the tile size comes only in qgis-trunk.
> > Do you have any public WMS url that can be used to make further tests?
> > Cheers
> > -- Giovanni --
> > ________ Information from NOD32 ________
> > This message was checked by NOD32 Antivirus System for Linux Mail Server.
> > http://www.nod32.com
