[Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
Patrice Vetsel patrice at kagou.fr
Wed Oct 12 21:23:37 PDT 2011
I'm searching to do the same (with no luck) on Mac because gdal1.9 is supporting the french cadastre system : edigeo
Regards
Le 13 oct. 2011 à 00:22, karsten a écrit :
> Thanks Even, that is very good news.
> I am trying to compile on windows with no luck. What was your procedure to
> build gdal and the gdal FGB plug-in (in case you did that ;) ) ?
> I was using packages from http://www.gisinternals.com/sdk/  (like
> http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-dev.zip
> e.g. ) and MSVC 2010 Express.
karsten at terragis.net
> Thanks
> Karsten
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Wednesday, October 12, 2011 12:46 PM
> To: qgis-user at lists.osgeo.org; karsten at terragis.net
> Subject: Re: [Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
> Le mercredi 12 octobre 2011 21:38:20, karsten a écrit :
>> Hi,
>> I was wondering if the ESRI file geodatabase format now can be used with
>> QGIS because gdal/ogr 1.9 apparently contains that driver ..?
>> So the question is whether I would e able use a file geodatabase in a (if
>> needed custom built ) QGIS when I would have a gdal 1.9 compiled with file
>> geodatabase support on my system or would there need to be additional
>> changes to the QGIS itself needed to enable this ?
> No change required in QGIS. It's abstracted by OGR API. It works already
> provided that you build GDAL against the FileGDB SDK and link QGIS against
> this GDAL build.
>> Cheers Karsten
>> Karsten Vennemann
>> Principal
>> Terra GIS LTD
>> 2119 Boyer Ave E
>> Seattle, WA  98112
>> USA
>> www.terragis.net <http://www.terragis.net/>
>> Email scanned by PC Tools - No viruses or spyware found.
>> (Email Guard: 7.0.0.27, Virus/Spyware Database: 6.18500)
>> http://www.pctools.com/
> Qgis-user mailing list
Patrice Vetsel
patrice at kagou.fr
http://blog.kagou.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111013/1f3d0243/attachment.html>
