[Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
Rainer M Krug r.m.krug at gmail.com
Thu Oct 13 00:17:17 PDT 2011
On Wed, Oct 12, 2011 at 9:45 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le mercredi 12 octobre 2011 21:38:20, karsten a écrit :
> > Hi,
> > I was wondering if the ESRI file geodatabase format now can be used with
> > QGIS because gdal/ogr 1.9 apparently contains that driver ..?
> > So the question is whether I would e able use a file geodatabase in a (if
> > needed custom built ) QGIS when I would have a gdal 1.9 compiled with
> file
> > geodatabase support on my system or would there need to be additional
> > changes to the QGIS itself needed to enable this ?
> No change required in QGIS. It's abstracted by OGR API. It works already
> provided that you build GDAL against the FileGDB SDK and link QGIS against
> this GDAL build.
Is it possible to do this dynamically, i.e. without recompiling / installing
QGIS?
So can I change gdal dynamically?
Rainer
> > Cheers Karsten
> > Karsten Vennemann
> > Principal
> > Terra GIS LTD
> > 2119 Boyer Ave E
> > Seattle, WA  98112
> > USA
> > www.terragis.net <http://www.terragis.net/>
> > Email scanned by PC Tools - No viruses or spyware found.
> > (Email Guard: 7.0.0.27, Virus/Spyware Database: 6.18500)
> > http://www.pctools.com/
> Qgis-user mailing list
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax (F):       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111013/74ebb17a/attachment.html>
