[Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
Jürgen E. Fischer jef at norbit.de
Thu Oct 13 01:31:36 PDT 2011
Hi Rainer,
On Thu, 13. Oct 2011 at 09:17:17 +0200, Rainer M Krug wrote:
> On Wed, Oct 12, 2011 at 9:45 PM, Even Rouault <[1]even.rouault at mines-paris.org> wrote:
> > No change required in QGIS. It's abstracted by OGR API. It works already
> > provided that you build GDAL against the FileGDB SDK and link QGIS against
> > this GDAL build.
> Is it possible to do this dynamically, i.e. without recompiling /
> installing QGIS?
If QGIS is already built against the GDAL you equip with FileGDB, you don't
need to rebuild it.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
