[Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
Rainer M Krug
r.m.krug at gmail.com
Thu Oct 13 01:44:02 PDT 2011
On Thu, Oct 13, 2011 at 10:31 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Rainer,
> On Thu, 13. Oct 2011 at 09:17:17 +0200, Rainer M Krug wrote:
> > On Wed, Oct 12, 2011 at 9:45 PM, Even Rouault <[1]
> even.rouault at mines-paris.org> wrote:
> > > No change required in QGIS. It's abstracted by OGR API. It works
> already
> > > provided that you build GDAL against the FileGDB SDK and link QGIS
> against
> > > this GDAL build.
> > Is it possible to do this dynamically, i.e. without recompiling /
> > installing QGIS?
> If QGIS is already built against the GDAL you equip with FileGDB, you don't
> need to rebuild it.
So am I right in assuming, that if QGIS is build against e.g. gdal 1.7 and I
want to use gdal 1.9, I have to re-build QGIS - is this correct?
Rainer
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111013/dcd8ec8d/attachment.html>
