[Qgis-user] Aggregation of polygons into vector grid
Sebastian Schubert schubert.seb at googlemail.com
Thu Oct 13 05:38:57 PDT 2011
On 05/10/11 07:10, Micha Silver wrote:
> On Tue, 2011-10-04 at 16:55 +0200, Sebastian Schubert wrote:
>> Hi,
>> I have a map with several polygons i, each having a certain value x_i. I
>> want to calculate the average value of x in a rectangular grid. Each
>> cell j of this grid includes (parts of) several polygons with A_ij being
>> the area of the part of polygon i being in grid cell j. With that the
>> average value in grid cell j is
>> x_j = sum_i A_ij x_i / (sum_i A_ij)
>> I was able to create a grid with Vector > Research Tools > Vector grid.
>> Now each cell of this grid should include the average value of all
>> polygons inside the cell (as described above).
>> Any idea how to do that?
> You probably want to look at the GRASS module v.rast.stats
Thanks for the hint. This, however, does exactly the opposite.
Statistics of raster based values controlled by a vector file. I have
the values in the vector polygons and I want to calculate the statistics
based on the pixels of a raster map.
What I did was basically convert the vector map to a very fine raster
file and then use the function
r.resamp.stats
to calculate the values for the wanted coarse resolution.
Cheers
Sebastian
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111013/95008b75/attachment.sig>
