[Qgis-user] Mapping in the southern hemisphere
Gerhardus Geldenhuis gerhardus.geldenhuis at gmail.com
Wed Oct 19 12:57:40 PDT 2011
Some feedback:
It works brilliantly now but the path was strewn with thorns. One more
problem of my own making was that the program that I used to convert my UTM
UPS format into dd mm ss.ss to do the Georeferencing uses north and south
and not + and - so I had +17 instead of -17 which also did not help. This
thus bring me to another question is there a way to universally change the
input method of co-ordinates within a project rather than to have to convert
between various formats the whole time. I thought there were but setting my
project to EPSG:32735 does not change the co-ordinate input methods for the
GeoReferencing plugin not thus the co-ordinates displayed in the bottom of
the screen change to UTM format.
Regards
2011/10/19 Gerhardus Geldenhuis <gerhardus.geldenhuis at gmail.com>
> Sigh,
> Thank you for all the replies. It is bloody confusing and a barrier of
> entry to using GIS programs I think. I intent to write up my experience when
> I am done so hopefully I can contribute in some way for the next person
> going through this pain. It might be useful if the dialogue boxes in QGIS
> would make no assumptions or use specific conventions and allow one to enter
> all data or at least clearly see what assumptions are being made with
> regards to a naming standard for a grid location.
> Regards
> 2011/10/19 Barend Köbben <kobben at itc.nl>
>> I beg to differ!
>> 35S is indeed zone 35, suothern hemishpere part. I trust places like
>> http://spatialreference.org/ref/epsg/32735/
>> More then WikiPedia...
>> Barend Köbben (Senior Lecturer)
>> ITC - University of Twente, Faculty of Geo-Information
>> Science and Earth Observation
>> PO Box 217, 7500AE Enschede (The Netherlands)
>> +31-(0)53 4874 253
>> On 19-10-11 20:47, "Gerhardus Geldenhuis" <gerhardus.geldenhuis at gmail.com
>> wrote:
>> >Hi John,Thank you for the reply.
>> >Unless I am mistaken 35S is very much in the northern hemisphere. Both
>> >http://en.wikipedia.org/wiki/File:LA2-Africa-UTM-zones.png and
>> >http://en.wikipedia.org/wiki/File:Utm-zones.jpg indicates to me that 35S
>> >is in the northern hemisphere and also my GPS which I trust more than
>> >wikipedia indicated that my UTM zone and band were 35K. Now personally I
>> >always take wikipedia with a pinch of salt but I am sure this is accurate
>> >information.
>> >Regards
>> >On Wed, Oct 19, 2011 at 7:27 PM, John Bryant <johnwbryant at gmail.com>
>> >wrote:
>> >I think you should be able to use EPSG:32735 for zone 35 south.  Search
>> >for 35S in the Project Properties dialogue, make sure to set the drop
>> >down for "Search for" to "Name".
>> >Cheers
>> >John
>> >On Wed, Oct 19, 2011 at 11:13 AM, Gerhardus Geldenhuis
>> ><gerhardus.geldenhuis at gmail.com> wrote:
>> >Hi It seems QGIS is a bit partial to the northern hemisphere. Is there an
>> >available source for UTM Zones in the northern hemisphere. I am looking
>> >for UTM 35K. I am currently trying to enter a custom grid but would much
>> >prefer to use and existing and reliable source of grid information.
>> >Appologies if I got the terminology mixed up.
>> >Just to clarify, I am using Map Datum WGS84, UTM Zone 35, UTM Band K. All
>> >my data is in UTM UPS format.
>> >This is hampering me a bit at the moment because I have managed to
>> >georeference my scanned images but because there is not southern
>> >hemisphere available it thinks it is in the northern hemisphere and turns
>> >everything upside down.
>> >Regards
>> >_______________________________________________
>> >Qgis-user mailing list
>> >Qgis-user at lists.osgeo.org
>> >http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Faculty of Geo-Information Science and Earth Observation (ITC)
>> Chamber of Commerce: 501305360000
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for
>> the addressee only. If you are not the intended recipient, you are hereby
>> notified that any disclosure, copying, distribution or action in relation to
>> the content of this information is strictly prohibited. If you have received
>> this e-mail by mistake, please delete the message and any attachment and
>> inform the sender by return e-mail. ITC accepts no liability for any error
>> or omission in the message content or for damage of any kind that may arise
>> as a result of e-mail transmission.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111019/c9938d08/attachment.html>
