[Qgis-user] Missing Georeferencer Plugin QGIS 1.7.0-Wroclaw
William Kyngesburye
woklist at kyngchaos.com
Wed Oct 19 15:10:58 PDT 2011
On Oct 19, 2011, at 3:26 PM, paul caruana galizia wrote:
> Hello,
> I've just installed QGIS 1.7.0-Wroclaw on my Mac (OS X 10.5.8). I've found and downloaded a number of plugins, but the Georeferencer plugin doesn't appear in the list of available plugins.
> Where can I find the Georeferencer plugin and how do I install it?
> Thanks very much for your help.
Did you install my package (kyngchaos.com)? The Georeferencer is there. Check the plugin manager and make sure it's enabled. Also make sure you have all the required frameworks installed (see the readme and my download page). The georeferencer uses GSL, and that's a separate framework not in the GDAL Complete package, so it's easy to miss.
And, update to 1.7.1 - it uses an installer package, which enforces the requirements so you don't miss something.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
