[Qgis-user] Debian Wheezy packages for QGIS 1.7.1
Jerry Bond gbond at rochester.rr.com
Sat Oct 22 13:17:22 PDT 2011
On Wednesday, October 19, 2011 9:29:07 am Niccolo Rigacci wrote:
> Hi to all,
> there are QGIS 1.7.1 packages for Debian Wheezy (testing), i386
> and amd64 architectures. The repository is apt-gettable:
> deb http://debian.gfoss.it/  wheezy  main
> On the same repository packages for Debian Squeeze are just for
> QGIS 1.7, I'm sorry for that.
> Thanks to developers which mantains the Debian files and all the
> other required packages.
We now have 32 and 64bit packages in our testing Community Repo, where they
will stay while users test the install:
deb  http://main.mepis-deb.org/mepiscr/testrepo/  mepis11cr  test
After a short time, they will be moved to
deb  http://main.mepis-deb.org/mepiscr/repo/  mepis11cr  main non-free
The packager commented: "The source packages from the debian.gfoss.it
repository should build just fine on squeeze. It looks like they built their
squeeze packages on a system with the wheezy libgeos files installed so their
package depends on them, but the wheezy libgeos is not required to build qgis
- the squeeze version works just fine."
Hope this helps somebody else
Jerry
