[Qgis-user] Modifying raster information?
G. Allegri giohappy at gmail.com
Tue Oct 25 00:37:50 PDT 2011
Hi Agus,
AFAIK you cannot do it with a ready to use tool in Qgis. You could use the
Raster->Conversion->Formats Conversion frontend to gdal_translate and set
the image output dimensions proportional to the pizel size ratio from
between your source and the required output pixel size. Otherwise you could
manually set the -tr option inside the gdalwarp frontend,
Raster->Projection->Reprojection, like this: http://bit.ly/tr3mGU
giovanni
[2] http://www.gdal.org/gdalwarp.html
2011/10/25 Agustin Lobo <alobolistas at gmail.com>
> Hi!
> We have a raster layer with wrong settings (in particular, wrong pixel
> size). Is it possible
> to edit these values? We have changed the resolution in R and it would
> be possible
> with grass also, but could this be done in qgis directly?
> Agus
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111025/d5fa9444/attachment.html>
