[Qgis-user] Modifying raster information?
G. Allegri giohappy at gmail.com
Tue Oct 25 02:26:03 PDT 2011
PS: for affine transformation you could also use the world file parameters
from your georeferenced raster...
2011/10/25 G. Allegri <giohappy at gmail.com>
> Hi Agus,
> AFAIK you cannot do it with a ready to use tool in Qgis. You could use the
> Raster->Conversion->Formats Conversion frontend to gdal_translate and set
> the image output dimensions proportional to the pizel size ratio from
> between your source and the required output pixel size. Otherwise you could
> manually set the -tr option inside the gdalwarp frontend,
> Raster->Projection->Reprojection, like this: http://bit.ly/tr3mGU
> giovanni
> [2] http://www.gdal.org/gdalwarp.html
> 2011/10/25 Agustin Lobo <alobolistas at gmail.com>
>> Hi!
>> We have a raster layer with wrong settings (in particular, wrong pixel
>> size). Is it possible
>> to edit these values? We have changed the resolution in R and it would
>> be possible
>> with grass also, but could this be done in qgis directly?
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111025/1b17ee21/attachment.html>
