[Qgis-user] Double line Feature
Matej Mailing mailing at tam.si
Tue Oct 25 14:09:20 PDT 2011
Thanks to all of you!
This is it - all current issues solved! :-)
QGIS rules.
With best regards,
Matej
2011/10/25 Lauri Kajan <lauri.kajan at gmail.com>
> On Tue, Oct 25, 2011 at 9:48 PM, Matej Mailing <mailing at tam.si> wrote:
> > This is almost it! :-)
> > Now we get a lot of polygons - is it possible to combine all the polygons
> > into one object (so that there are no "borders" inside it)?
> > Thanks,
> > Matej
> > 2011/10/25 Albin Blaschka <albin.blaschka at standortsanalyse.net>
> >> Am 25.10.2011 13:52, schrieb Matej Mailing:
> >>> Basically we need this to define some sort of "protected area" (for
> >>> example, 30 cm in both sides from the cable) along some
> >>> telecommunication network cables (mainly optical) and therefore I don't
> >>> think only the representation would be sufficient. Probably some plugin
> >>> that would create polygon with a centralized line that we are "snapping
> >>> to" and with defined area (width) would be even better than just two
> >>> lines, because this way we could define some color of fill of that
> >>> closed "part" around cable in our projects for example. Hopefully I
> >>> explained it enough clearly, if you need more information, please let
> me
> >>> know :-)
> >> Hello!
> >> That sounds like you need a buffer :-)
> >> In QGIS, you find this functionality under Vector (fTools plugin) ->
> >> Geoprocessing (or similar, I have just the german version at hand at the
> >> moment...)
> >> Albin
> >> | Albin Blaschka, Mag.rer.nat.
> >> | Etrichstrasse 26, A-5020 Salzburg
> >> | * www.albinblaschka.info * www.thinkanimal.info *
> >> | - It's hard to live in the mountains, hard but not hopeless!
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hi Matej,
> Sure it is possible.
> You can use dissolve tool from Vector -> geoprosessing tools -> dissolve.
> And in the dialog select dissolve all.
> At least in the qgis 1.7.1 the dissolve tool is included in the buffer
> tool. In the buffer dialog you can check a dissolve option to dissolve
> all the buffers.
> Hopefully this helps.
> -Lauri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111025/9b222a2a/attachment.html>
