[Qgis-user] How Do I Set Field Calculator Units For Area
Alister Hood alister.hood at synergine.com
Thu Sep 1 15:27:55 PDT 2011
Hi Giovanni,
Either you are mistaken, or there is a bug.  I have OTFR enabled, and the field calculator returns the same area when I set the project CRS to EPSG:32074 (which uses feet), as it does when I set the project CRS to any normal CRS which uses metres.
Alister
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: Thursday, 1 September 2011 7:58 p.m.
> To: Alister Hood
> Cc: qgis-user at lists.osgeo.org
> Subject: RE: [Qgis-user] How Do I Set Field Calculator Units For Area
> Calculations are in the project CRS unit if OTFR is enabled, if not, the
> layer CRS unit is set in the general tab of the project properties.
> cheers
> -- Giovanni --
> On Thu, 2011-09-01 at 11:18 +1200, Alister Hood wrote:
> > Hi there,
> > I *think* the area calculations are always in the unit for the layer's
> > CRS.  So you could either:
> > - find out what this unit is, and convert the areas to square feet by
> > multiplying by the correct factor, or
> > - convert the layer to a CRS which uses square feet.
> > N.B. there is a feature request to enable coordinate conversion in the
> > field calculator (although I didn't mention that it would be useful also
> > for area and length calculations).  See http://hub.qgis.org/issues/4078
> > Alister
> > > Date: Wed, 31 Aug 2011 11:18:32 -0500
> > > From: Andrew Novak <novak.andj at gmail.com>
> > > Subject: [Qgis-user] How Do I Set Field Calculator Units For Area
> > > 	Calcs?
> > > To: qgis-user at lists.osgeo.org
> > > Message-ID:
> > <CAO0Lqnon=aJMKGUb=BPacqxgn+PGn4G2vpe8sn=epxyT+pKtbw at mail.gmail.com>
> > > Content-Type: text/plain; charset="iso-8859-1"
> > > The area calculations from my field calculator are in an unknown unit.
> > I
> > > simply want my units to be square feet. How can I set my units in the
> > field
> > > calculator??
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
