[Qgis-user] How Do I Set Field Calculator Units For Area
Giovanni Manghi giovanni.manghi at gmail.com
Sat Sep 3 02:28:45 PDT 2011
> Either you are mistaken, or there is a bug.
I hope I am mistaken!
>  I have OTFR enabled, and the field calculator returns the same area
> when I set the project CRS to EPSG:32074 (which uses feet), as it does
> when I set the project CRS to any normal CRS which uses metres.
are you sure you don't have "feet" configured as preferred unit when
OTRF is unselected?
cheers
-- Giovanni --
