[Qgis-user] How Do I Set Field Calculator Units For Area
Alister Hood alister.hood at synergine.com
Sat Sep 3 16:32:37 PDT 2011
I get the same results in the field calculator regardless of what the preferred unit is.
-----Original Message-----
From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Sent: Sat 03/09/2011 21:28
To: Alister Hood
Cc: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] How Do I Set Field Calculator Units For Area
> Either you are mistaken, or there is a bug.
I hope I am mistaken!
>  I have OTFR enabled, and the field calculator returns the same area
> when I set the project CRS to EPSG:32074 (which uses feet), as it does
> when I set the project CRS to any normal CRS which uses metres.
are you sure you don't have "feet" configured as preferred unit when
OTRF is unselected?
cheers
-- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110904/75bd74e4/attachment.html>
