[Qgis-user] MrSid
Giovanni Manghi giovanni.manghi at gmail.com
Fri Sep 2 08:01:01 PDT 2011
Don't know if is your case, but for instance if you use the
Ubuntugis_unstable repo and the nightly builds one, you must remember
that qgis-trunk is compiled against gdal 1.6 (available in the main
Ubuntu repo) but probably you have also installed gdal 1.8 from the
Ubuntugis repo, so if you add the mrsid support you are adding it to
gdal 1.8, but qgis-trunk uses gdal 1.6.
cheers
-- Giovanni --
On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
> I am not sure about nightly. I do have the ubuntugis and unstable
> repositories added. I do not currently have nightly enabled.
> all the best,
> Lee
> On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
> <giovanni.manghi at gmail.com> wrote:
>         on qhat platform? Linux/Ubuntu? are you using both the
>         Ubuntugis and
>         nightly builds repositories?
>         cheers
>         -- Giovanni --
>         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
>         > I seem to have finally incorporated MrSID into gdal:
>         > gdalinfo --formats | grep MrSID
>         >   MrSID (ro): Multi-resolution Seamless Image Database
>         (MrSID)
>         >   JP2MrSID (ro): MrSID JPEG2000
>         > However, if I try to add a .sid file into qgis I still get
>         an
>         > unsupported raster format error.
>         > Any thoughts on how to get this to work?
>         > all the best,
>         > Lee
>         > _______________________________________________
>         > Qgis-user mailing list
>         > Qgis-user at lists.osgeo.org
>         > http://lists.osgeo.org/mailman/listinfo/qgis-user
