[Qgis-user] MrSid
Lee muellerl at gmail.com
Fri Sep 2 08:03:43 PDT 2011
That very well might be my case. Do you have a recommendation to fix it? I
installed qgis through the software manager, and not from source. So I'm
automatically imagining it was the trunk install. Although a lot of these
issues are somewhat over my head.
all the best,
Lee
On Fri, Sep 2, 2011 at 11:01 AM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Don't know if is your case, but for instance if you use the
> Ubuntugis_unstable repo and the nightly builds one, you must remember
> that qgis-trunk is compiled against gdal 1.6 (available in the main
> Ubuntu repo) but probably you have also installed gdal 1.8 from the
> Ubuntugis repo, so if you add the mrsid support you are adding it to
> gdal 1.8, but qgis-trunk uses gdal 1.6.
> cheers
> -- Giovanni --
> On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
> > I am not sure about nightly. I do have the ubuntugis and unstable
> > repositories added. I do not currently have nightly enabled.
> > all the best,
> > Lee
> > On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
> > <giovanni.manghi at gmail.com> wrote:
> >         on qhat platform? Linux/Ubuntu? are you using both the
> >         Ubuntugis and
> >         nightly builds repositories?
> >         cheers
> >         -- Giovanni --
> >         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
> >         > I seem to have finally incorporated MrSID into gdal:
> >         > gdalinfo --formats | grep MrSID
> >         >   MrSID (ro): Multi-resolution Seamless Image Database
> >         (MrSID)
> >         >   JP2MrSID (ro): MrSID JPEG2000
> >         > However, if I try to add a .sid file into qgis I still get
> >         an
> >         > unsupported raster format error.
> >         > Any thoughts on how to get this to work?
> >         > all the best,
> >         > Lee
> >         > _______________________________________________
> >         > Qgis-user mailing list
> >         > Qgis-user at lists.osgeo.org
> >         > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110902/cb91e4b8/attachment.html>
