[Qgis-user] MrSid
Lee muellerl at gmail.com
Wed Sep 7 05:53:24 PDT 2011
My issue with attempting to install qgis from source, as directed in the
guides is an error when trying to use ccmake
" CMake Error at cmake/Flex.cmake:14 (MESSAGE):
   flex not found - aborting "
This error has prevented me from going any further.
Again, to recap, I have mrsid incorporated into gdal, but it does not work
in qgis. Giovanni has suggested qgis might automatically be falling back to
an older version of gdal, whereas I have incorporated mrsid into 1.8.
all the best,
Lee
On Fri, Sep 2, 2011 at 11:03 AM, Lee <muellerl at gmail.com> wrote:
> That very well might be my case. Do you have a recommendation to fix it? I
> installed qgis through the software manager, and not from source. So I'm
> automatically imagining it was the trunk install. Although a lot of these
> issues are somewhat over my head.
> all the best,
> Lee
> On Fri, Sep 2, 2011 at 11:01 AM, Giovanni Manghi <
> giovanni.manghi at gmail.com> wrote:
>> Don't know if is your case, but for instance if you use the
>> Ubuntugis_unstable repo and the nightly builds one, you must remember
>> that qgis-trunk is compiled against gdal 1.6 (available in the main
>> Ubuntu repo) but probably you have also installed gdal 1.8 from the
>> Ubuntugis repo, so if you add the mrsid support you are adding it to
>> gdal 1.8, but qgis-trunk uses gdal 1.6.
>> cheers
>> -- Giovanni --
>> On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
>> > I am not sure about nightly. I do have the ubuntugis and unstable
>> > repositories added. I do not currently have nightly enabled.
>> > all the best,
>> > Lee
>> > On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
>> > <giovanni.manghi at gmail.com> wrote:
>> >         on qhat platform? Linux/Ubuntu? are you using both the
>> >         Ubuntugis and
>> >         nightly builds repositories?
>> >         cheers
>> >         -- Giovanni --
>> >         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
>> >         > I seem to have finally incorporated MrSID into gdal:
>> >         > gdalinfo --formats | grep MrSID
>> >         >   MrSID (ro): Multi-resolution Seamless Image Database
>> >         (MrSID)
>> >         >   JP2MrSID (ro): MrSID JPEG2000
>> >         > However, if I try to add a .sid file into qgis I still get
>> >         an
>> >         > unsupported raster format error.
>> >         > Any thoughts on how to get this to work?
>> >         > all the best,
>> >         > Lee
>> >         > _______________________________________________
>> >         > Qgis-user mailing list
>> >         > Qgis-user at lists.osgeo.org
>> >         > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110907/6a71f548/attachment.html>
