[Qgis-user] MrSid
Lee muellerl at gmail.com
Thu Sep 8 12:54:54 PDT 2011
I've been able to revert back to Wroclaw from the newer trunk. I fixed the
issues I was having there.
That said, I have still been unable to get the MrSID issue fixed. GDAL shows
that it has MrSID support. I get an unsupported format error when trying to
add a .sid raster to qgis. Going to help - about in QGIS shows me it is
currently using GDAL 1.8.
all the best,
Lee
On Thu, Sep 8, 2011 at 2:24 PM, Lee <muellerl at gmail.com> wrote:
> Due to the above error, I cannot follow the guide as instructed. I follow
> it to that point, and the error is spit out.
> At this point, due to other suggestions, I am utlilizing a qgis "master"
> which cautions heavy construction. I would much prefer to revert back to
> Wroclaw, but upon my last attempt the qgis install failed entirely due to a
> change in dependencies. I could not figure out a way around it, and am still
> using the "master" version.
> It seems the more I dig into this, the more problems that develop. This is
> troubling, as it seems others have been able to incorporate MrSID without
> much trouble. Unfortunately it seems so many different things have been
> tried, that the program is such a mess none of the current solutions are
> working as intended. I am at a loss of how to proceed.
> all the best,
> Lee
> On Thu, Sep 8, 2011 at 9:23 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Wed, Sep 7, 2011 at 2:53 PM, Lee <muellerl at gmail.com> wrote:
>> > My issue with attempting to install qgis from source, as directed in the
>> > guides is an error when trying to use ccmake
>> > " CMake Error at cmake/Flex.cmake:14 (MESSAGE):
>> >    flex not found - aborting "
>> > This error has prevented me from going any further.
>> Are you following the guide in INSTALL in the top of the source tree?
>> Note that the guide in 1.7 still refers to svn but you should retrieve
>> the sources from github now.
>> sudo apt-get build-dep qgis
>> should get you all the build dependencies you need including flex.
>> Regards
>> Tim
>> > Again, to recap, I have mrsid incorporated into gdal, but it does not
>> work
>> > in qgis. Giovanni has suggested qgis might automatically be falling back
>> to
>> > an older version of gdal, whereas I have incorporated mrsid into 1.8.
>> > all the best,
>> > Lee
>> > On Fri, Sep 2, 2011 at 11:03 AM, Lee <muellerl at gmail.com> wrote:
>> >> That very well might be my case. Do you have a recommendation to fix
>> it? I
>> >> installed qgis through the software manager, and not from source. So
>> I'm
>> >> automatically imagining it was the trunk install. Although a lot of
>> these
>> >> issues are somewhat over my head.
>> >> all the best,
>> >> Lee
>> >> On Fri, Sep 2, 2011 at 11:01 AM, Giovanni Manghi
>> >> <giovanni.manghi at gmail.com> wrote:
>> >>> Don't know if is your case, but for instance if you use the
>> >>> Ubuntugis_unstable repo and the nightly builds one, you must remember
>> >>> that qgis-trunk is compiled against gdal 1.6 (available in the main
>> >>> Ubuntu repo) but probably you have also installed gdal 1.8 from the
>> >>> Ubuntugis repo, so if you add the mrsid support you are adding it to
>> >>> gdal 1.8, but qgis-trunk uses gdal 1.6.
>> >>> cheers
>> >>> -- Giovanni --
>> >>> On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
>> >>> > I am not sure about nightly. I do have the ubuntugis and unstable
>> >>> > repositories added. I do not currently have nightly enabled.
>> >>> > all the best,
>> >>> > Lee
>> >>> > On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
>> >>> >         on qhat platform? Linux/Ubuntu? are you using both the
>> >>> >         Ubuntugis and
>> >>> >         nightly builds repositories?
>> >>> >         cheers
>> >>> >         -- Giovanni --
>> >>> >         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
>> >>> >         > I seem to have finally incorporated MrSID into gdal:
>> >>> >         > gdalinfo --formats | grep MrSID
>> >>> >         >   MrSID (ro): Multi-resolution Seamless Image Database
>> >>> >         (MrSID)
>> >>> >         >   JP2MrSID (ro): MrSID JPEG2000
>> >>> >         > However, if I try to add a .sid file into qgis I still get
>> >>> >         an
>> >>> >         > unsupported raster format error.
>> >>> >         > Any thoughts on how to get this to work?
>> >>> >         > all the best,
>> >>> >         > Lee
>> >>> >         > _______________________________________________
>> >>> >         > Qgis-user mailing list
>> >>> >         > Qgis-user at lists.osgeo.org
>> >>> >         > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110908/f8343d16/attachment.html>
