[Qgis-user] MrSid
Tim Sutton lists at linfiniti.com
Fri Sep 9 02:22:19 PDT 2011
Hi
On Thu, Sep 8, 2011 at 9:54 PM, Lee <muellerl at gmail.com> wrote:
> I've been able to revert back to Wroclaw from the newer trunk. I fixed the
> issues I was having there.
> That said, I have still been unable to get the MrSID issue fixed. GDAL shows
> that it has MrSID support. I get an unsupported format error when trying to
> add a .sid raster to qgis. Going to help - about in QGIS shows me it is
> currently using GDAL 1.8.
In ccmake when you configure your QGIS build, make sure it points to
your hand build gdal with sid support.
At runtime, make sure your library path prefers the hand build gdal
lib directory over any system installed gdal libs you may have.
Note also that installing multiple QGIS instances on linux is tricky
and the best way to test is to have only one installed (so check all
qgis related stuff is uninstalled in apt, then double check in the
filesystem before you build your own).
Regards
Tim
> all the best,
> Lee
> On Thu, Sep 8, 2011 at 2:24 PM, Lee <muellerl at gmail.com> wrote:
>> Due to the above error, I cannot follow the guide as instructed. I follow
>> it to that point, and the error is spit out.
>> At this point, due to other suggestions, I am utlilizing a qgis "master"
>> which cautions heavy construction. I would much prefer to revert back to
>> Wroclaw, but upon my last attempt the qgis install failed entirely due to a
>> change in dependencies. I could not figure out a way around it, and am still
>> using the "master" version.
>> It seems the more I dig into this, the more problems that develop. This is
>> troubling, as it seems others have been able to incorporate MrSID without
>> much trouble. Unfortunately it seems so many different things have been
>> tried, that the program is such a mess none of the current solutions are
>> working as intended. I am at a loss of how to proceed.
>> all the best,
>> Lee
>> On Thu, Sep 8, 2011 at 9:23 AM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi
>>> On Wed, Sep 7, 2011 at 2:53 PM, Lee <muellerl at gmail.com> wrote:
>>> > My issue with attempting to install qgis from source, as directed in
>>> > the
>>> > guides is an error when trying to use ccmake
>>> > " CMake Error at cmake/Flex.cmake:14 (MESSAGE):
>>> >    flex not found - aborting "
>>> > This error has prevented me from going any further.
>>> Are you following the guide in INSTALL in the top of the source tree?
>>> Note that the guide in 1.7 still refers to svn but you should retrieve
>>> the sources from github now.
>>> sudo apt-get build-dep qgis
>>> should get you all the build dependencies you need including flex.
>>> Regards
>>> Tim
>>> > Again, to recap, I have mrsid incorporated into gdal, but it does not
>>> > work
>>> > in qgis. Giovanni has suggested qgis might automatically be falling
>>> > back to
>>> > an older version of gdal, whereas I have incorporated mrsid into 1.8.
>>> > all the best,
>>> > Lee
>>> > On Fri, Sep 2, 2011 at 11:03 AM, Lee <muellerl at gmail.com> wrote:
>>> >> That very well might be my case. Do you have a recommendation to fix
>>> >> it? I
>>> >> installed qgis through the software manager, and not from source. So
>>> >> I'm
>>> >> automatically imagining it was the trunk install. Although a lot of
>>> >> these
>>> >> issues are somewhat over my head.
>>> >> all the best,
>>> >> Lee
>>> >> On Fri, Sep 2, 2011 at 11:01 AM, Giovanni Manghi
>>> >> <giovanni.manghi at gmail.com> wrote:
>>> >>> Don't know if is your case, but for instance if you use the
>>> >>> Ubuntugis_unstable repo and the nightly builds one, you must remember
>>> >>> that qgis-trunk is compiled against gdal 1.6 (available in the main
>>> >>> Ubuntu repo) but probably you have also installed gdal 1.8 from the
>>> >>> Ubuntugis repo, so if you add the mrsid support you are adding it to
>>> >>> gdal 1.8, but qgis-trunk uses gdal 1.6.
>>> >>> cheers
>>> >>> -- Giovanni --
>>> >>> On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
>>> >>> > I am not sure about nightly. I do have the ubuntugis and unstable
>>> >>> > repositories added. I do not currently have nightly enabled.
>>> >>> > all the best,
>>> >>> > Lee
>>> >>> > On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
>>> >>> >         on qhat platform? Linux/Ubuntu? are you using both the
>>> >>> >         Ubuntugis and
>>> >>> >         nightly builds repositories?
>>> >>> >         cheers
>>> >>> >         -- Giovanni --
>>> >>> >         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
>>> >>> >         > I seem to have finally incorporated MrSID into gdal:
>>> >>> >         > gdalinfo --formats | grep MrSID
>>> >>> >         >   MrSID (ro): Multi-resolution Seamless Image Database
>>> >>> >         (MrSID)
>>> >>> >         >   JP2MrSID (ro): MrSID JPEG2000
>>> >>> >         > However, if I try to add a .sid file into qgis I still
>>> >>> > get
>>> >>> >         an
>>> >>> >         > unsupported raster format error.
>>> >>> >         > Any thoughts on how to get this to work?
>>> >>> >         > all the best,
>>> >>> >         > Lee
>>> >>> >         > _______________________________________________
>>> >>> >         > Qgis-user mailing list
>>> >>> >         > Qgis-user at lists.osgeo.org
>>> >>> >         > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>>  * QGIS programming and support services
>>>  * Mapserver and PostGIS based hosting plans
>>>  * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
