[Qgis-user] Re: Problem installing 1.7
Nomeneta Saili nome.saili at gmail.com
Fri Sep 9 12:47:54 PDT 2011
 Hi Gerardo,
In my case i was able to install QGIS1.7 but i was not able to launch
it. I have Kaspersky.
What i did was i paused Kaspersky and then reinstall QGIS1.7. After
that i was able to launch QGIS1.7.
I didn't think at the time it was a antivirus issue as i was able to
run QGIS1.7 on another windows machine with Kaspersky but i found out
that the particular windows machine with Kaspersky that QGIS1.7 didn't
run on was blocking some important installation files of QGIS from
running. i.e there were different configuration of Kaspersky. After
pausing Kaspersky and reinstalling QGIS1.7 i was able to launch
QGIS1.7 afterwards when i resumed Kaspersky protection.
Give it a try. Either that or just make sure that your antivirus
programs don't block certain instances of when QGIS1.7 is trying to
install certain files.
Hope this would help
Cheers
On Fri, Sep 9, 2011 at 12:17 AM,  <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>        qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: MrSid (Lee)
>   2. Re: Problem installing  1.7 (Ramon Andi?ach)
>   3. Qgis and Google (Starke Holger, Mag.)
>   4. Re: Problem installing 1.7 (Tim Sutton)
>   5. Date format in shape (Daniel.Gnerre at vevey.ch)
> Message: 1
> Date: Thu, 8 Sep 2011 15:54:54 -0400
> From: Lee <muellerl at gmail.com>
> Subject: Re: [Qgis-user] MrSid
> To: Tim Sutton <lists at linfiniti.com>
> Cc: qgis-user at lists.osgeo.org
> Message-ID:
>        <CAL4bd_wzqK7=NpxkN4tX5R+NQbGxRzmjzMqAPLzPfMRiZcto6A at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> I've been able to revert back to Wroclaw from the newer trunk. I fixed the
> issues I was having there.
> That said, I have still been unable to get the MrSID issue fixed. GDAL shows
> that it has MrSID support. I get an unsupported format error when trying to
> add a .sid raster to qgis. Going to help - about in QGIS shows me it is
> currently using GDAL 1.8.
> all the best,
> Lee
> On Thu, Sep 8, 2011 at 2:24 PM, Lee <muellerl at gmail.com> wrote:
>> Due to the above error, I cannot follow the guide as instructed. I follow
>> it to that point, and the error is spit out.
>> At this point, due to other suggestions, I am utlilizing a qgis "master"
>> which cautions heavy construction. I would much prefer to revert back to
>> Wroclaw, but upon my last attempt the qgis install failed entirely due to a
>> change in dependencies. I could not figure out a way around it, and am still
>> using the "master" version.
>> It seems the more I dig into this, the more problems that develop. This is
>> troubling, as it seems others have been able to incorporate MrSID without
>> much trouble. Unfortunately it seems so many different things have been
>> tried, that the program is such a mess none of the current solutions are
>> working as intended. I am at a loss of how to proceed.
>> all the best,
>> Lee
>> On Thu, Sep 8, 2011 at 9:23 AM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi
>>> On Wed, Sep 7, 2011 at 2:53 PM, Lee <muellerl at gmail.com> wrote:
>>> > My issue with attempting to install qgis from source, as directed in the
>>> > guides is an error when trying to use ccmake
>>> > " CMake Error at cmake/Flex.cmake:14 (MESSAGE):
>>> >    flex not found - aborting "
>>> > This error has prevented me from going any further.
>>> Are you following the guide in INSTALL in the top of the source tree?
>>> Note that the guide in 1.7 still refers to svn but you should retrieve
>>> the sources from github now.
>>> sudo apt-get build-dep qgis
>>> should get you all the build dependencies you need including flex.
>>> Regards
>>> Tim
>>> > Again, to recap, I have mrsid incorporated into gdal, but it does not
>>> work
>>> > in qgis. Giovanni has suggested qgis might automatically be falling back
>>> to
>>> > an older version of gdal, whereas I have incorporated mrsid into 1.8.
>>> > all the best,
>>> > Lee
>>> > On Fri, Sep 2, 2011 at 11:03 AM, Lee <muellerl at gmail.com> wrote:
>>> >> That very well might be my case. Do you have a recommendation to fix
>>> it? I
>>> >> installed qgis through the software manager, and not from source. So
>>> I'm
>>> >> automatically imagining it was the trunk install. Although a lot of
>>> these
>>> >> issues are somewhat over my head.
>>> >> all the best,
>>> >> Lee
>>> >> On Fri, Sep 2, 2011 at 11:01 AM, Giovanni Manghi
>>> >> <giovanni.manghi at gmail.com> wrote:
>>> >>> Don't know if is your case, but for instance if you use the
>>> >>> Ubuntugis_unstable repo and the nightly builds one, you must remember
>>> >>> that qgis-trunk is compiled against gdal 1.6 (available in the main
>>> >>> Ubuntu repo) but probably you have also installed gdal 1.8 from the
>>> >>> Ubuntugis repo, so if you add the mrsid support you are adding it to
>>> >>> gdal 1.8, but qgis-trunk uses gdal 1.6.
>>> >>> cheers
>>> >>> -- Giovanni --
>>> >>> On Fri, 2011-09-02 at 10:57 -0400, Lee wrote:
>>> >>> > I am not sure about nightly. I do have the ubuntugis and unstable
>>> >>> > repositories added. I do not currently have nightly enabled.
>>> >>> > all the best,
>>> >>> > Lee
>>> >>> > On Fri, Sep 2, 2011 at 10:52 AM, Giovanni Manghi
>>> >>> >         on qhat platform? Linux/Ubuntu? are you using both the
>>> >>> >         Ubuntugis and
>>> >>> >         nightly builds repositories?
>>> >>> >         cheers
>>> >>> >         -- Giovanni --
>>> >>> >         On Fri, 2011-09-02 at 10:40 -0400, Lee wrote:
>>> >>> >         > I seem to have finally incorporated MrSID into gdal:
>>> >>> >         > gdalinfo --formats | grep MrSID
>>> >>> >         >   MrSID (ro): Multi-resolution Seamless Image Database
>>> >>> >         (MrSID)
>>> >>> >         >   JP2MrSID (ro): MrSID JPEG2000
>>> >>> >         > However, if I try to add a .sid file into qgis I still get
>>> >>> >         an
>>> >>> >         > unsupported raster format error.
>>> >>> >         > Any thoughts on how to get this to work?
>>> >>> >         > all the best,
>>> >>> >         > Lee
>>> >>> >         > _______________________________________________
>>> >>> >         > Qgis-user mailing list
>>> >>> >         > Qgis-user at lists.osgeo.org
>>> >>> >         > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>>  * QGIS programming and support services
>>>  * Mapserver and PostGIS based hosting plans
>>>  * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110908/f8343d16/attachment-0001.html
> Message: 2
> Date: Fri, 9 Sep 2011 06:21:05 +0800
> From: Ramon Andi?ach <custard at westnet.com.au>
> Subject: Re: [Qgis-user] Problem installing  1.7
> To: qgis-user at lists.osgeo.org
> Message-ID: <278CA61A-7B9C-413B-936B-7A3D63045F34 at westnet.com.au>
> Content-Type: text/plain; charset="us-ascii"
> On 08/09/2011, at 23:06, Gerardo Jimenez <gejst5 at hotmail.com> wrote:
> [snip]
>> b) I have two machines wit win 7 32b with avira and zone alarm and not a problem installing Qgis 1.7
>> The issue is pretty recent in 4 diferent machines, one using avira, another kaspersky and Macafee
> There has definitely been install errors reported on this list traceable to Kapersky virus scanners.
> -ramon.
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110909/bbdc70c9/attachment-0001.html
> Message: 3
> Date: Fri, 9 Sep 2011 08:44:07 +0200
> From: "Starke Holger, Mag." <Starke at hagel.at>
> Subject: [Qgis-user] Qgis and Google
> To: "Qgis-user at lists.osgeo.org" <Qgis-user at lists.osgeo.org>
> Message-ID:
>        <373C79BCF4148F4DA955037A16DD4346422082513D at HAGEL-MAIL1.intern.hagel.at>
> Hi all,
> I´ve a Problem with the Google Maps Layers.
> I added a Google Maps Layer using the "Google Layers" Plugin (Projection: EPSG:900913). Then I added an own Polygon-Layer (EPSG:31287) and enabled the "On the fly"-Transformation Option before. Both Layers are displayed, but there is an offset of about 20 meters. Is that due to inaccuracy of the transformation or is it a bug in QGIS?
> Holger
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110909/6d173fc3/attachment-0001.html
> Message: 4
> Date: Fri, 9 Sep 2011 08:51:30 +0200
> From: Tim Sutton <lists at linfiniti.com>
> To: Gerardo Jimenez <gejst5 at hotmail.com>
> Message-ID:
>        <CALCNqkY6pmykx5JvsJMiwT8-vBwTMp8gFcfwQm5_3y+yR77FWA at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi
> On Thu, Sep 8, 2011 at 5:06 PM, Gerardo Jimenez <gejst5 at hotmail.com> wrote:
>> Thanks for your anwsers, nevertheless
>> a) I always install qGis as an administrator since v1.4.
>> I am about to begin an introductory class on GIS and I really want to use
>> Qgis
> Since QGIS is pretty portable, if you are really getting stuck, you
> should be able to take your installation from one computer and copy
> the whole Quantum GIS over to the *same location* on another machine.
> Then create a shortcut on the desktop / start menu pointing to
> c:\program files\Quantum GIS\bin\qgis.bat. Don't shortcut directly to
> qgis.exe as the bat file is needed to set up the environment. In some
> cases you may also need to run vcredist on the computer, though that
> would normally not be required.
> Regards
> Tim
>> Thanks before hand
>> Gerardo Jiménez Delgado
>> Instituto de Investigaciones Antropológicas
>> Universidad Nacional Autónoma de México
>> Ciudad Universitaria s/n
>> Coyoacan 04510 Mexico City
>> Mexico 56 22 95 16
> Skype: timlinux
> Message: 5
> Date: Fri, 9 Sep 2011 08:46:59 +0200
> From: Daniel.Gnerre at vevey.ch
> Subject: [Qgis-user] Date format in shape
> Message-ID:
>        <OF86E19F58.CA080C06-ONC1257906.00253836-C1257906.002547B0 at vevey.ch>
> Hi list,
> Is it possible to handle a date format attribute in a shape ? When I open
> a shape containing a date format attribute, it is impossible to edit data
> in it. And when I create a new shape, I cannot choose a date format. Am I
> obliged to work with PostGIS ?
> Sorry of this question has already been treated...
> Thanks
> Daniel
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110909/b781e01e/attachment.html
> End of Qgis-user Digest, Vol 67, Issue 13
