[Qgis-user] Problem installing 1.7
Gerardo Jimenez gejst5 at hotmail.com
Fri Sep 9 09:06:14 PDT 2011
It worked!!!
Thanks very much
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
> From: lists at linfiniti.com
> Date: Fri, 9 Sep 2011 08:51:30 +0200
> Subject: Re: [Qgis-user] Problem installing 1.7
> To: gejst5 at hotmail.com
> CC: qgis-user at lists.osgeo.org
> Hi
> On Thu, Sep 8, 2011 at 5:06 PM, Gerardo Jimenez <gejst5 at hotmail.com> wrote:
> > Thanks for your anwsers, nevertheless
> > a) I always install qGis as an administrator since v1.4.
> > b) I have two machines wit win 7 32b with avira and zone alarm and not a
> > problem installing Qgis 1.7
> > The issue is pretty recent in 4 diferent machines, one using avira, another
> > kaspersky and Macafee
> > I am about to begin an introductory class on GIS and I really want to use
> > Qgis
> Since QGIS is pretty portable, if you are really getting stuck, you
> should be able to take your installation from one computer and copy
> the whole Quantum GIS over to the *same location* on another machine.
> Then create a shortcut on the desktop / start menu pointing to
> c:\program files\Quantum GIS\bin\qgis.bat. Don't shortcut directly to
> qgis.exe as the bat file is needed to set up the environment. In some
> cases you may also need to run vcredist on the computer, though that
> would normally not be required.
> Regards
> Tim
> > Thanks before hand
> > Coyoacan 04510 Mexico City
> > Mexico 56 22 95 16
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110909/5ace792b/attachment.html>
