[Qgis-user] Raster with extra points
VE wanderdoc at googlemail.com
Sun Sep 11 02:16:20 PDT 2011
Thank you very much Alex and Saber,
I will try the both options.
VE
11.09.2011
----- Folgende Nachricht wurde empfangen -----
Absender: Alex Mandel
Empfänger: qgis-user
Zeit: 2011-09-11, 04:19:43
Betreff: Re: [Qgis-user] Raster with extra points
On 09/10/2011 01:24 PM, VE wrote:
> Dear all,
> I made a raster map in QGIS 1.7.0 and added a few points (important locations) to it (as a csv-file with adjustment of the projection, it looks very good on the programm screen).
> If I just save the picture only the monitor part will be saved. The raster map is larger and if I zoom out to show all necessary points on the screen the map will be too small (without details).
> How could I save the map with the points in the original resolution (i.e that I can print it as a poster later)? Can one "merge" the points with the raster map in a new raster file?
> Thank you very much in advance!
> Wanderdoc
> P.S. My first post here, do not beat me if I broke any rules!
> 10.09.2011
Make a map composition with the print composer, you can specify the page
size and resolution then save as an image or a pdf.
Enjoy,
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110911/2155205f/attachment.html>
