[Qgis-user] Raster with extra points
Alex Mandel tech_dev at wildintellect.com
Sat Sep 10 19:19:43 PDT 2011
On 09/10/2011 01:24 PM, VE wrote:
> Dear all,
> I made a raster map in QGIS 1.7.0 and added a few points (important locations) to it (as a csv-file with adjustment of the projection, it looks very good on the programm screen).
> If I just save the picture only the monitor part will be saved. The raster map is larger and if I zoom out to show all necessary points on the screen the map will be too small (without details).
> How could I save the map with the points in the original resolution (i.e that I can print it as a poster later)? Can one "merge" the points with the raster map in a new raster file?
> Thank you very much in advance!
> Wanderdoc
> P.S. My first post here, do not beat me if I broke any rules!
> wanderdoc at googlemail.com
> 10.09.2011
Make a map composition with the print composer, you can specify the page
size and resolution then save as an image or a pdf.
Enjoy,
Alex
