[Qgis-user] Raster with extra points
Saber Razmjooei razmjooeis at faunalia.co.uk
Sat Sep 10 14:09:22 PDT 2011
One way I can think of is:
Convert your points to raster using GDAL plugin (Raster menu). I reckon
it should be the same cell size as your main raster.
Merge the 2 rasters (from Raster menu), and it should give you a new
raster with your points embedded.
Hope that helps.
Saber
On Sat, 2011-09-10 at 22:24 +0200, VE wrote:
> Dear all,
> I made a raster map in QGIS 1.7.0 and added a few points (important
> locations) to it (as a csv-file with adjustment of the projection, it
> looks very good on the programm screen).
> If I just save the picture only the monitor part will be saved. The
> raster map is larger and if I zoom out to show all necessary points on
> the screen the map will be too small (without details).
> How could I save the map with the points in the original resolution
> (i.e that I can print it as a poster later)? Can one "merge" the
> points with the raster map in a new raster file?
> Thank you very much in advance!
> Wanderdoc
> P.S. My first post here, do not beat me if I broke any rules!
> wanderdoc at googlemail.com
> 10.09.2011
> Qgis-user mailing list
