Re: [Qgis-user] QGIS 1.7 Wrocław_problem copying entities after Joins
Ramon Andiñach custard at westnet.com.au
Tue Sep 13 06:41:26 PDT 2011
-ramon.
On 13/09/2011, at 20:10, "s.lazarescu" <stanca.lazarescu at gmail.com> wrote:
> Dear all,
> I'm using the latest version of QGIS, happy to be able to use the 'joins'
> function. However, I'm stuck trying to exploit the information in an excel
> after having joined two layers. Here's the whole story:
> I have a vector layer (PostGis) representing geolocated enteprises of a
> region in France. To this vector layer I joined a geometryless table
> (PostGis) in order to enrich the information of the former layer (primary
> key of the two layers = the SIRET code indicating the activity field of the
> enterprises).
> After having joined the two layers, what I need to do is select certain
> entities and try to copy them in an excel table for further statistical
> anylisis. The problem is that, no matter what the character enconding, only
> the information from the mother vector layer is copied, while all the joined
> colomns remain empty.
> Thanks a lot for helping
> Stanca
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-1-7-Wroc-aw-problem-copying-entities-after-Joins-tp6787206p6787206.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
