[Qgis-user] Profile Tool
Alister Hood alister.hood at synergine.com
Wed Sep 14 03:49:43 PDT 2011
Yes,
I imagine if there was a 64 bit installer it would not work, since the
OSGeo4W and QGIS distribution for Windows is all 32bit.
Sent: Wednesday, 14 September 2011 10:33 p.m.
To: Alister Hood
Cc: qgis-user at lists.osgeo.org; david.fawcett at gmail.com;
garcia.silva at gmail.com
Subject: Re: [Qgis-user] Profile Tool
On 14/09/2011 13:27, Alister Hood wrote:
Yes, I learned it on the list - there are plugins with other Python
dependencies that need to be installed the same way.
For anyone else doing it, I forgot to mention that it only works if you
use an installer built for the same version of Python that QGIS uses
i.e. an installer for Python 2.6 or 3 will not work with Python 2.5.
and on the Shapely site, there's no Win32 installer for 64 bit matched
to python 2.5. So I used the 32 bit installer on my Win7 64 machine, and
it went OK.
	Sent: Wednesday, 14 September 2011 10:01 p.m.
	To: Alister Hood
	On 01/09/2011 01:18, Alister Hood wrote:
		Hi guys,
		You can manually extract the files from the shapely
installer (using
		e.g. Izarc or 7zip, or possibly just by renaming it as
.zip or
		something), and put them in the right places.
		You need to put the shapely folder (from inside PURELIB)
in e.g.
		C:\OSGeo4W\apps\Python25\Lib\site-packages\, and the
geos.dll and
		libgeos-3-2-2.dll in I think C:\OSGeo4W\bin, although
instead of
		installing those I seem to have got it working by
editing
C:\OSGeo4W\apps\Python25\Lib\site-packages\shapely\geos.py to use the
		lib from OSGeo4W instead (C:\OSGeo4W\bin\geos_c.dll).
	Hi Alister:
	Your trick to unzip and manually place shapely 1.2 into the
python\site_packages\ dir worked fine. Many thanks.
	Micha
	This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110914/38cf35e7/attachment.html>
