[Qgis-user] QGIS 1.7 project fails to load in QGIS 1.7
Alister Hood alister.hood at synergine.com
Thu Sep 15 21:09:52 PDT 2011
As well as using debugview, you might want to check what messages are printed to stdout.
There are probably other ways to do this on Windows, but what I do is modify the startup batch file for the msys rxvt so that it runs anything from the qgis batch file which is needed to be able to start qgis.  Then I can start qgis from rxvt and see the output ☺... like on a real operating system (except I still need debugview as well, and I don't know that that would be the case on a real operating system).
Alister
> Date: Fri, 16 Sep 2011 10:54:44 +0800
> From: Ramon Andi?ach <custard at westnet.com.au>
> Subject: [Qgis-user] QGIS 1.7 project fails to load in QGIS 1.7
> To: qgis-user at lists.osgeo.org
> Message-ID: <7DD72FFC-80FD-4B9C-8176-FDFA02CFFBC0 at westnet.com.au>
> Content-Type: text/plain;	charset=us-ascii
> Hi there,
> I have a peculiar problem where some of my project files that say they're 1.7
> are suddenly refusing to open.
> Debug view is silent on the matter.
> This is on windows7 64-bit with a 1.7 install via osgeo
> I'm getting a similar result with a nearby standalone 1.7 install.
> Are there any likely causes?
> -ramon.
