[Qgis-user] Re: QGIS 1.7 project fails to load in QGIS 1.7
magerlin MAP at ramboll.dk
Fri Sep 16 01:12:58 PDT 2011
Ramon Andinach wrote:
> Hi there,
> I have a peculiar problem where some of my project files that say they're
> 1.7 are suddenly refusing to open. ...
Have you tried simply to open the qgs projekt file in a text or XML editor
to check whether the XML structure seems OK?
I have experienced some times Qgis hanging or breaking down and in that
process not seem to get the qgs file "finished". A full qgs file should end
with the XML-tag: </qgis>
I must ad, that I have not had any luck manually fixing the qgs project
file, but it ought to be possible if you know the needed tag structure.
Regards Morten
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-1-7-project-fails-to-load-in-QGIS-1-7-tp6799617p6800165.html
Sent from the qgis-user mailing list archive at Nabble.com.
