[Qgis-user] advice needed - merge attributes
Andreas Neumann a.neumann at carto.net
Sun Sep 18 04:42:41 PDT 2011
just to let you know - as of yesterday "Sum" is also available in the
merge dialogue. Thanks to Jürgen Fischer!
This means, if your areas before the merge were correct, using the sum
operator you will get correct areas/lengths after the merge as well.
Andreas
PS: available in QGIS trunk
On 09/17/2011 11:45 AM, David wrote:
> Andreas - Thank you for your suggestions:  at the moment the most important variable is Area so I do need to add the areas of the merged polygons to get a new total.   The other variables in the list are names which I maybe have to type in anyway.   I'm going to try your idea and the suggestions I received from other people.
> David
> ________________________________
> From: Andreas Neumann <a.neumann at carto.net>
> To: qgis-user at lists.osgeo.org
> Sent: Friday, 16 September 2011, 19:51
> Subject: Re: [Qgis-user] advice needed - merge attributes
> Hi,
> This should work.
> After selecting and merging the polygons a table should pop up where you
> can select for each polygon the new attributes it should get. You can:
> * select one individual polygons attributes to be used or
> * min
> * max
> * mean
> * average
> However, I see that sum is not offered. Would you need the sum function?
> If yes, this should be rather easy to implement.
> Andreas
> On 09/16/2011 04:08 PM, David wrote:
>> Hi everyone,
>> On a shapefile, given to me by the person who created it, I need to merge some polygons to make larger units.    For example, select four adjacent polygons and use the merge tool and you get one large polygon.   Great.   However, on the attributes table what seems to happen is that instead of combining the various values (size, perimeter etc) three of the four polygons have disappeared leaving just one with its original data unchanged.   Would some kind person tell me what I'm doing wrong?
>> Thanks in advance.
>> David Asquith
>> UK
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
