[Qgis-user] Reset GISDBASE for GRASS plugin
Brad Nesom gisbradokla at live.com
Tue Sep 20 08:02:10 PDT 2011
On winxp
Apparently I already knew that. (just forgot)
I have system variables as follows...
GISDBASE = c:\documents and Settings\userprofile
myname\GrassData\HLND_Data\HLND
GISRC = c:\documents and setting/userprofile myname/.grass6
GRASSDIR = C:\Documents and Settings\userprofile myname\GrassData
However since updating my osgeo4w installation I now have no .grass6 file.
And there is a .grassrc6 file and a .grasswx6 file.
grass starts (standalone) but the error in qgis persists.
On Tue, Sep 20, 2011 at 4:52 AM, Micha Silver <micha at arava.co.il> wrote:
>  On 19/09/2011 17:21, Brad Nesom wrote:
> @Micha,
> I have this exact problem on osge4w.
> where did you unset GISRC?
> I did that from the Linux terminal. On Windows try this:
> Browse to (on Win 7) C:\Users\<your user name>\AppData\Local\Temp\
> and find the most recent folder named grass6--wxyz (ends in 4 random
> digits). Inside that folder is a gisrc file. Edit the file to reflect the
> correct GISDBASE path.  Maybe that will help.
> On Mon, Sep 19, 2011 at 5:54 AM, Micha Silver <micha at arava.co.il> wrote:
>> (responding to myself)
>> Found it: unset GISRC
>> Now QGIS starts properly, and asks for the path to the GISDBASE, etc
>> On Mon, 2011-09-19 at 12:31 +0300, Micha Silver wrote:
>> > How can I get out of this loop:
>> > Starting QGIS I get this error:
>> > terminate called after throwing an instance of 'QgsGrass::Exception'
>> >   what():  G_getenv(): Variable GISDBASE not set
>> > If I start with qgis --noplugins it opens, without GRASS, of course. But
>> > there's no way now to reset the GISDBASE without the plugin. Catch 22...
>> > I'm on Scientific Linux 6.1 with a self compiled version 1.7. Where can
>> > I find QGIS settings for the GRASS plugin?
>> > Thanks,
>> > Micha
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110920/9f11f1ec/attachment.html>
