[Qgis-user] Reset GISDBASE for GRASS plugin
Micha Silver
micha at arava.co.il
Tue Sep 20 12:32:24 PDT 2011
On Tue, 2011-09-20 at 10:02 -0500, Brad Nesom wrote:
> On winxp
> Apparently I already knew that. (just forgot)
> I have system variables as follows...
> GISDBASE = c:\documents and Settings\userprofile myname\GrassData
> \HLND_Data\HLND
> GISRC = c:\documents and setting/userprofile myname/.grass6
> GRASSDIR = C:\Documents and Settings\userprofile myname\GrassData
> However since updating my osgeo4w installation I now have no .grass6
> file.
> And there is a .grassrc6 file and a .grasswx6 file.
I think those are from GRASS itslef, not QGIS.
> grass starts (standalone) but the error in qgis persists.
I'm not sure, but I have a feeling that QGIS doesn't even use
these .files anymore on Windows, but rather puts everything into the
windows registry.
> On Tue, Sep 20, 2011 at 4:52 AM, Micha Silver <micha at arava.co.il>
> wrote:
> On 19/09/2011 17:21, Brad Nesom wrote:
> > @Micha,
> > I have this exact problem on osge4w.
> > where did you unset GISRC?
> I did that from the Linux terminal. On Windows try this:
> Browse to (on Win 7) C:\Users\<your user name>\AppData\Local
> \Temp\
> and find the most recent folder named grass6--wxyz (ends in 4
> random digits). Inside that folder is a gisrc file. Edit the
> file to reflect the correct GISDBASE path. Maybe that will
> help.
> > On Mon, Sep 19, 2011 at 5:54 AM, Micha Silver
> > <micha at arava.co.il> wrote:
> > (responding to myself)
> > Found it: unset GISRC
> > Now QGIS starts properly, and asks for the path to
> > the GISDBASE, etc
> > On Mon, 2011-09-19 at 12:31 +0300, Micha Silver
> > wrote:
> > > How can I get out of this loop:
> > > Starting QGIS I get this error:
> > > terminate called after throwing an instance of
> > 'QgsGrass::Exception'
> > > what(): G_getenv(): Variable GISDBASE not set
> > > If I start with qgis --noplugins it opens, without
> > GRASS, of course. But
> > > there's no way now to reset the GISDBASE without
> > the plugin. Catch 22...
> > > I'm on Scientific Linux 6.1 with a self compiled
> > version 1.7. Where can
> > > I find QGIS settings for the GRASS plugin?
> > > Thanks,
> > > Micha
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110920/82e58300/attachment.html>
