[Qgis-user] flip vector line direction
Andreas Neumann a.neumann at carto.net
Wed Sep 21 02:29:11 PDT 2011
 Thanks Nathan for this tool.
 In my opinion this should be a standard part of the QGIS edit tools. So
 many people need direction swapping. It should be delivered with QGIS by
 default.
 Just my opinion.
 Andreas
 On Wed, 21 Sep 2011 19:23:42 +1000, Nathan Woodrow wrote:
> Hi Flavio,
> I wrote a tool to do that a couple of months back.  Search for "Swap"
> in the plugin installer in QGIS.
> It will swap the currently selected line/s.  Layer must be in edit
> mode.
> - Nathan
> On Wed, Sep 21, 2011 at 6:23 PM, flavio rigolon  wrote:
>> Hi all,
>>  apologize if this item was just discussed on this list.
>> Is there a tool in QGIS to change (reverse) the digitization
>> direction
>> of a linear feature?
>> I've found the command in GRASS: v.edit map=line_map_name tool=flip
>> but this seems only works for GRASS layer (not SHP nore PG layer)
>> and
>> the selection
>> is not interactive (selection is by cat, bbox, coords,...). I know
>> I'm
>> asking too much...
>> .....but any suggestion is appreciated.
>> Thanks in advance
>> flavio
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org [1]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:flavio.rigolon at gmail.com
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
