[Qgis-user] flip vector line direction
Nathan Woodrow madmanwoo at gmail.com
Wed Sep 21 02:31:41 PDT 2011
Yeah I agree.  It's on my to do list.  Might have a go at it over the
weekend some time rather than study ;)
- Nathan
On Wed, Sep 21, 2011 at 7:29 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi,
> Thanks Nathan for this tool.
> In my opinion this should be a standard part of the QGIS edit tools. So
> many people need direction swapping. It should be delivered with QGIS by
> default.
> Just my opinion.
> Andreas
> On Wed, 21 Sep 2011 19:23:42 +1000, Nathan Woodrow wrote:
>> Hi Flavio,
>> I wrote a tool to do that a couple of months back.  Search for "Swap"
>> in the plugin installer in QGIS.
>> It will swap the currently selected line/s.  Layer must be in edit
>> mode.
>> - Nathan
>> On Wed, Sep 21, 2011 at 6:23 PM, flavio rigolon  wrote:
>>  Hi all,
>>>  apologize if this item was just discussed on this list.
>>> Is there a tool in QGIS to change (reverse) the digitization
>>> direction
>>> of a linear feature?
>>> I've found the command in GRASS: v.edit map=line_map_name tool=flip
>>> but this seems only works for GRASS layer (not SHP nore PG layer)
>>> and
>>> the selection
>>> is not interactive (selection is by cat, bbox, coords,...). I know
>>> I'm
>>> asking too much...
>>> .....but any suggestion is appreciated.
>>> Thanks in advance
>>> flavio
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org [1]
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>> Links:
>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> [3] mailto:flavio.rigolon at gmail.**com <flavio.rigolon at gmail.com>
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110921/bbf8239b/attachment.html>
