[Qgis-user] Problems with saga module interface 0.17
Agustin Lobo alobolistas at gmail.com
Thu Sep 22 03:03:26 PDT 2011
That was it, problem solved.
Thanks
Agus
2011/9/22 Giovanni Manghi <giovanni.manghi at gmail.com>:
> Have you installed the "framework processing manager" plugin?
> Cheers
> -- Giovanni --
> On Thu, 2011-09-22 at 10:16 +0200, Agustin Lobo wrote:
>> Since few days ago I cannot install the saga module interface 0.17. Qgis claims
>> The plugin depends on some components missing on your system. You need
>> to install the following Python module in order to enable it:
>> processingplugin.processing
>> I do have the saga python bindings 2.0.7+dfsg-0.5~lucid
>> Any advice on what to do?
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
