[Qgis-user] Problems with saga module interface 0.17
Agustin Lobo alobolistas at gmail.com
Fri Sep 30 02:09:17 PDT 2011
Unfortunately, actually still have the problem on another machine,
also with ubuntu lucid (and with the framework plugin of qgis
installed):
The puglin installer states:
The plugin is broken. Python said:
/usr/lib/python2.6/dist-packages/_saga_api.so: undefined symbol:
_ZNK23CSG_Regression_Multiple5Get_REv
alobo at alobo-laptop:~$ dpkg -l | grep saga
ii  libsaga
2.0.7+svn1155+11~lucid1                         SAGA GIS development
files
ii  libsaga-dev
files
ii  python-saga
2.0.7+svn1155+11~lucid1                         SAGA GIS python
bindings
ii  saga
2.0.7+svn1155+11~lucid1                         System for Automated
Geoscientific Analyses
alobo at alobo-laptop:~$ dpkg -l | grep qgis
ii  libqgis-dev                                   1.7.1-1~lucid1
                           Quantum GIS - development files
ii  libqgis1.7.1                                  1.7.1-1~lucid1
                           Quantum GIS - shared libraries
ii  python-qgis                                   1.7.1-1~lucid1
                           Python bindings to Quantum GIS
ii  python-qgis-common                            1.7.1-1~lucid1
                           Python bindings to Quantum GIS -
architecture-independ
ii  qgis                                          1.7.1-1~lucid1
                           Geographic Information System (GIS)
ii  qgis-api-doc                                  1.7.1-1~lucid1
                           Quantum GIS API documentation
ii  qgis-common                                   1.7.1-1~lucid1
                           Quantum GIS - architecture-independent data
ii  qgis-plugin-grass                             1.7.1-1~lucid1
                           GRASS plugin for Quantum GIS
ii  qgis-plugin-grass-common                      1.7.1-1~lucid1
                           GRASS plugin for Quantum GIS -
ii  qgis-providers                                1.7.1-1~lucid1
                           collection of data providers to Quantum GIS
ii  qgis-providers-common                         1.7.1-1~lucid1
- architec
ii  qgis-sqlanywhere1.7.1                         1.7.1-1~lucid1
                           Quantum GIS sql anywhere plugin and
provider
Thanks
2011/9/22 Agustin Lobo <alobolistas at gmail.com>:
> That was it, problem solved.
> Thanks
> Agus
> 2011/9/22 Giovanni Manghi <giovanni.manghi at gmail.com>:
>> Have you installed the "framework processing manager" plugin?
>> Cheers
>> -- Giovanni --
>> On Thu, 2011-09-22 at 10:16 +0200, Agustin Lobo wrote:
>>> Since few days ago I cannot install the saga module interface 0.17. Qgis claims
>>> The plugin depends on some components missing on your system. You need
>>> to install the following Python module in order to enable it:
>>> processingplugin.processing
>>> I do have the saga python bindings 2.0.7+dfsg-0.5~lucid
>>> Any advice on what to do?
>>> Agus
