[Qgis-user] Importing Open Street Map files
Noli Sicad nsicad at gmail.com
Sat Sep 24 22:05:08 PDT 2011
Try using Spatialite Tools (i.e. importing OSM data to spatialite,
then use spatialite OSM data in QGIS.
So the OSM supporting tools are now:
    * spatialite_osm_net: genarating a Network (aka Graph) from OSM XML
    * spatialite_osm_map: generating multi-layered map from OSM XML
    * spatialite_osm_raw: simply acquiring OSM XML into DB tables
(fully preserving the XML layout)
Noli
On 9/25/11, Mick <bareman at tpg.com.au> wrote:
> I need to import several Open Street Map .osm files in such a way that
> I get a separate column for each and every tag in the files.
> I have tried various tweaks to the XML source without success.
> I had a go at creating a mysql database but ended up with a mess due to
> my limited knowledge.
> I looked at using postgress but can't get anywhere with it.
> I even looked at the source code for the OSM import plugin but python is
> too different to C for me to make sense of.
> I'm getting prematurely old and don't absorb knowledge as easily as I
> once could.
> Could some kind soul point me to crib sheets, how-tos, tools or other
> guidance to get me going.
> The tools I have available are ArchLinux with QGIS 1.7, mysql,
> postgress, grass & MapInfo 7.8.
> The area I'm interested in covers Cornwall, Devon & Dorset north to the
> top of the Cottswolds.
> mick
> Qgis-user mailing list
