[Qgis-user] dificuldade de "snapping" na edição de vector
Giovanni Manghi giovanni.manghi at gmail.com
Sun Sep 25 14:55:44 PDT 2011
> In portuguese, you mean "Configurações" > Opções de Ressalto ?
yes
> I already tried that, but what value should i out in "tolerancia"? I
> put 0, 30, 300...nothing works!!!!!
What works better for you, pixels or map units. If using map units and
you have a project with a projected CRS then they are meters (or feets),
if you are working in WGS84 are degrees, so in this case you may want
really use pixels.
Cheers
-- Giovanni --
