[Qgis-user] bessel ellipsoid 1841
Barend Köbben kobben at itc.nl
Tue Sep 27 00:16:53 PDT 2011
FYI, the proj string does have a datum, one based on the Bessel ellipsoid
(which is a datum), but I agree with giovanni that the proj=longlat is
unlikely to be correct for your map. Neighbouring Netherlands uses the
Bessel datum, and a double stereographic projection (It's epsg:28992). But
also it is doubtful that was used in the 19th century (sorry). Nowadays
Germany uses Gauss-Kruger, Münsterland would be in EPSG Projection 31466 -
DHDN / 3-degree Gauss-Kruger zone 2 ...
Barend Köbben
ITC - University of Twente, Faculty of Geo-Information
Science and Earth Observation
PO Box 217, 7500AE Enschede (The Netherlands)
+31-(0)53 4874 253
On 26-09-11 23:02, "G. Allegri" <giohappy at gmail.com> wrote:
>It's quite unlikely that an earth centred datum has been used for your
>map, and the 4004 should only be used when the datum is unkonwn and we
>suppose that the ellipsoid origin is the earth centre... yet I don't know
>what the geodetic reference(s) was used in Germany along the 19th century.
>giovanni
>2011/9/26 Torsten Lange <tlange at gwdg.de>
>Hello,
>I have a historical map from 1855 from the Muensterland Basin, Germany.
>The
>map shows geographic coordinates, thus my colleague said most likely it's
>Bessel 1841 ellipsoid.
>QGis offers:
>Unknown datum based upon the Bessel 1841 ellipsoid EPSG:4004
>+proj=longlat +ellps=bessel +no_defs
>Why there is no datum? Shouldn't there be one?
>Thank you, Torsten
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
Faculty of Geo-Information Science and Earth Observation (ITC)
Chamber of Commerce: 501305360000
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
