[Qgis-user] bessel ellipsoid 1841
G. Allegri giohappy at gmail.com
Tue Sep 27 08:46:12 PDT 2011
Just a side note: the Bessel ellipsoid isn't a datum by itself. A datum is
defined by an ellipsoid, it's point of origin and various ancillary data
about its oriantation and, generally, by a geodetic network that realizes
it.
2011/9/27 Barend Köbben <kobben at itc.nl>
> FYI, the proj string does have a datum, one based on the Bessel ellipsoid
> (which is a datum), but I agree with giovanni that the proj=longlat is
> unlikely to be correct for your map. Neighbouring Netherlands uses the
> Bessel datum, and a double stereographic projection (It's epsg:28992). But
> also it is doubtful that was used in the 19th century (sorry). Nowadays
> Germany uses Gauss-Kruger, Münsterland would be in EPSG Projection 31466 -
> DHDN / 3-degree Gauss-Kruger zone 2 ...
> Barend Köbben
> ITC - University of Twente, Faculty of Geo-Information
> Science and Earth Observation
> PO Box 217, 7500AE Enschede (The Netherlands)
> +31-(0)53 4874 253
> On 26-09-11 23:02, "G. Allegri" <giohappy at gmail.com> wrote:
> >It's quite unlikely that an earth centred datum has been used for your
> >map, and the 4004 should only be used when the datum is unkonwn and we
> >suppose that the ellipsoid origin is the earth centre... yet I don't know
> >what the geodetic reference(s) was used in Germany along the 19th century.
> >giovanni
> >2011/9/26 Torsten Lange <tlange at gwdg.de>
> >Hello,
> >I have a historical map from 1855 from the Muensterland Basin, Germany.
> >The
> >map shows geographic coordinates, thus my colleague said most likely it's
> >Bessel 1841 ellipsoid.
> >QGis offers:
> >Unknown datum based upon the Bessel 1841 ellipsoid EPSG:4004
> >+proj=longlat +ellps=bessel +no_defs
> >Why there is no datum? Shouldn't there be one?
> >Thank you, Torsten
> >_______________________________________________
> >Qgis-user mailing list
> >Qgis-user at lists.osgeo.org
> >http://lists.osgeo.org/mailman/listinfo/qgis-user
> Faculty of Geo-Information Science and Earth Observation (ITC)
> Chamber of Commerce: 501305360000
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for
> the addressee only. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or action in relation to
> the content of this information is strictly prohibited. If you have received
> this e-mail by mistake, please delete the message and any attachment and
> inform the sender by return e-mail. ITC accepts no liability for any error
> or omission in the message content or for damage of any kind that may arise
> as a result of e-mail transmission.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110927/aaffc53d/attachment.html>
