[Qgis-user] Error in New Symbology
magerlin MAP at ramboll.dk
Tue Sep 27 04:40:33 PDT 2011
I am trying to use a symbology for a line shp layer with a line marked with a
circle in both ends. It is constructed as a "Simple Line" plus 2 "Marker
Lines" each putting a circle in either end of the line.
But as can be seen from the image below, the line appears only with a circle
at the start (both on map canvas and in print composer). And it can bee seen
that the legend has the wanted circle in both ends.
http://osgeo-org.1803224.n2.nabble.com/file/n6835633/New_Symbology_Error.png
I have tried with 2 different line layers with same error.
Regards
Morten
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-in-New-Symbology-tp6835633p6835633.html
Sent from the qgis-user mailing list archive at Nabble.com.
