[Qgis-user] Re: Error in New Symbology
magerlin MAP at ramboll.dk
Tue Sep 27 04:44:49 PDT 2011
Forgot to mention:
I am using Version 1.7 in Win 7.
The error is something new - I have used exactly the same design earlier in
version 1.7.
Regards Morten
magerlin wrote:
> I am trying to use a symbology for a line shp layer with a line marked
> with a circle in both ends. It is constructed as a "Simple Line" plus 2
> "Marker Lines" each putting a circle in either end of the line.
> But as can be seen from the image below, the line appears only with a
> circle at the start (both on map canvas and in print composer). And it can
> bee seen that the legend has the wanted circle in both ends.
> I have tried with 2 different line layers with same error.
> Regards
> Morten
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-in-New-Symbology-tp6835633p6835643.html
Sent from the qgis-user mailing list archive at Nabble.com.
