[Qgis-user] File-based Mastermap
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Wed Sep 28 02:38:54 PDT 2011
I need to deploy four stand-alone laptops with a basic GIS (data viewing
only) and have chosen QGIS for this. The data held is for the entire
county of Warwickshire, and one of the datasets I need to put on there is
MasterMap. Specifically the datasets I'm using are:
Topographic line: 3.7 million features
Topographic Area: 1.3 million features
Cartographic Text: 250,000 features
Given the dataset size, obviously the first choice is a database, but as
these are stand-alone laptops that must have the simplest setup possible
(they're going to be used out in the field away from tech-support) I've
ruled that option out.
I tried shapefile's but it turns out that spatial indexes in Shapefiles
are an ESRI-only thing, so the dataset takes literally minutes to load per
pan.
Can anyone can suggest a format I could use that would allow fluid viewing
of this data in QGIS? I have access to FME, so can convert to pretty much
any format.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/26b3b92c/attachment.html>
