[Qgis-user] File-based Mastermap
James Stott
James.Stott at npaconsult.co.uk
Wed Sep 28 02:42:01 PDT 2011
You can build spatial indexes for shapefiles in QGIS.
Open the properties dialog for the layer, then select the general tab.
There is a button for Create Spatial Index.
Not sure what version it was added.
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
jonathanmoules at warwickshire.gov.uk
Sent: 28 September 2011 10:39
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] File-based Mastermap
I need to deploy four stand-alone laptops with a basic GIS (data viewing
only) and have chosen QGIS for this. The data held is for the entire
county of Warwickshire, and one of the datasets I need to put on there
is MasterMap. Specifically the datasets I'm using are:
Topographic line: 3.7 million features
Topographic Area: 1.3 million features
Cartographic Text: 250,000 features
Given the dataset size, obviously the first choice is a database, but as
these are stand-alone laptops that must have the simplest setup possible
(they're going to be used out in the field away from tech-support) I've
ruled that option out.
I tried shapefile's but it turns out that spatial indexes in Shapefiles
are an ESRI-only thing, so the dataset takes literally minutes to load
per pan.
Can anyone can suggest a format I could use that would allow fluid
viewing of this data in QGIS? I have access to FME, so can convert to
pretty much any format.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it,
or disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject
to recording and/or monitoring in accordance with relevant legislation.
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/b5a4f26c/attachment.html>
Type: image/jpeg
Desc: NPA_Logo.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/b5a4f26c/attachment.jpg>
Type: image/jpeg
Desc: Email_Footer_News.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/b5a4f26c/attachment-0001.jpg>
