[Qgis-user] File-based Mastermap
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Wed Sep 28 02:47:50 PDT 2011
Hi James,
        Oooh, yep that seems to do it.
Thanks!
Jonathan
From:   "James Stott" <James.Stott at npaconsult.co.uk>
To:     <jonathanmoules at warwickshire.gov.uk>, <qgis-user at lists.osgeo.org>
Date:   28/09/2011 10:42
Subject:        RE: [Qgis-user] File-based Mastermap
You can build spatial indexes for shapefiles in QGIS.
Open the properties dialog for the layer, then select the general tab.
There is a button for Create Spatial Index.
Not sure what version it was added.
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
www.npaconsult.co.uk
mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
Sent: 28 September 2011 10:39
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] File-based Mastermap
I need to deploy four stand-alone laptops with a basic GIS (data viewing
only) and have chosen QGIS for this. The data held is for the entire
county of Warwickshire, and one of the datasets I need to put on there is
MasterMap. Specifically the datasets I'm using are:
Topographic line: 3.7 million features
Topographic Area: 1.3 million features
Cartographic Text: 250,000 features
Given the dataset size, obviously the first choice is a database, but as
these are stand-alone laptops that must have the simplest setup possible
(they're going to be used out in the field away from tech-support) I've
ruled that option out.
I tried shapefile's but it turns out that spatial indexes in Shapefiles
are an ESRI-only thing, so the dataset takes literally minutes to load per
pan.
Can anyone can suggest a format I could use that would allow fluid viewing
of this data in QGIS? I have access to FME, so can convert to pretty much
any format.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject to
recording and/or monitoring in accordance with relevant legislation.
Information and Registered Address
This Electronic Transmission is intended only for the attention of the
addressee. It may contain privileged and confidential information. If you
are not the person for whom it is intended, you must not copy, distribute
or take any action in reliance on it. If you have received this electronic
transmission in error please notify us immediately by telephone, delete
the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that
this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0)
01225 445548, Fax: +44 (0) 01225 312387, Website:
http://www.npaconsult.co.uk
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/7336351f/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/7336351f/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110928/7336351f/attachment-0001.jpe>
