[Qgis-user] Problem on RT Sql Layer : 1.0.27
Jules Kouadio sekedoua at gmail.com
Thu Sep 29 04:00:16 PDT 2011
Hello Sucameli.
In the shell  :
Python 2.4.3 (#1, Sep 21 2011, 20:06:00)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-51)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import psycopg2
>>> conn = psycopg2.connect("dbname=routing user=postgres")
 OK .
In Qgis
>>> import sys
>>> sys.version
'2.6.5 (r265:79063, Feb 28 2011, 21:55:56) \n[GCC 4.1.2 20080704 (Red Hat
4.1.2-50)]'
Thanks
2011/9/29 Giuseppe Sucameli <sucameli at faunalia.it>
> Hi Jules,
> > I've now Install psycopg2 2.4.2 and it run perfectly .
> how do you know it runs? did you try it from the shell?
> On Thu, Sep 29, 2011 at 12:23 PM, Jules Kouadio <sekedoua at gmail.com>
> wrote:
> > but i get always the same message when i try to run RT Sql Layer  .
> > Even in the qgis python console with the phyton command "import" psycopg2
> [[CUT]]
> > ImportError: No module named psycopg2
> To help you we need more info,
> the OS you run QGis on, the python version used by QGis.
> I know that some people have throuble on Debian OS after
> installing python 2.7 and keeping the 2.6 version installed.
> I don't know if your problem may be due to this, just tell us
> if the version of python running from the shell it's the same of
> the one used by QGis.
> To know the running python version, just open the qgis python
> console and run:
> import sys
> sys.version
> Regards.
> > 2011/9/29 Noli Sicad <nsicad at gmail.com>
> >> Download and install psycopg2 2.4.2.
> >> It is python package, not part of QGIS or QGIS plugins.
> >> Python-PostgreSQL Database Adapter
> >> http://pypi.python.org/pypi/psycopg2
> >> Noli
> >> On 9/29/11, Jules Kouadio <sekedoua at gmail.com> wrote:
> >> > Hello .
> >> > Installation is ok
> >> > I get this message when i try to run it
> >> > Couldn't import Python module 'psycopg2' for communication with
> PostgreSQL
> >> > database.
> >> > Its the same problem whith Postgis Manager Plugin.
> >> > My Os version is centos 5.5
> >> > Qgis version 1.8.0-Trunck
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110929/18326334/attachment.html>
