[Qgis-user] Using GRIB2 in QGIS
Giovanni Manghi giovanni.manghi at gmail.com
Fri Sep 30 09:46:06 PDT 2011
you need to check if it supported (out of the box, or at all) by
http://www.gdal.org/formats_list.html
http://www.gdal.org/ogr/ogr_formats.html
cheers
-- Giovanni --
On Fri, 2011-09-30 at 11:43 -0500, Ezra Boyd wrote:
> Hello,
> I am trying to use the Real Time Ocean Forecasting System
> (http://polar.ncep.noaa.gov/ofs/download.shtml?) archival data which
> is in the GRIB2 format using a hybrid model-based coordinate system.
> The data can be downloaded from here:
> http://data.nodc.noaa.gov/opendap/ncep/rtofs/contents.html
> Has anyone had any experience using GRIB2 in QGIS?  If so, please let
> me know how it worked out.  In particular, I need to get forecast data
> into a format where I can overlay a shapefile, but the wqgrib2 program
> won't work because hybrid coordinate system.
> Thanks,
> Ezra
> Qgis-user mailing list
