[Qgis-user] Using GRIB2 in QGIS
Brent Fraser bfraser at geoanalytic.com
Fri Sep 30 11:21:05 PDT 2011
Ezra,
   QGIS uses GDAL to read GRIB files.  GDAL's GRIB driver will not read
the files on the site you listed as the g2clib GDAL uses is too old
(v1.0.4) and does not support the GRIB GDT 3.204 Curvilinear Orthogonal
Grid  (supported in g2clib v 1.0.5).
Best Regards,
Brent Fraser
On 9/30/2011 10:43 AM, Ezra Boyd wrote:
> Hello,
> I am trying to use the Real Time Ocean Forecasting System
> (http://polar.ncep.noaa.gov/ofs/download.shtml?) archival data which
> is in the GRIB2 format using a hybrid model-based coordinate system.
> The data can be downloaded from here:
> http://data.nodc.noaa.gov/opendap/ncep/rtofs/contents.html
> Has anyone had any experience using GRIB2 in QGIS?  If so, please let
> me know how it worked out.  In particular, I need to get forecast data
> into a format where I can overlay a shapefile, but the wqgrib2 program
> won't work because hybrid coordinate system.
> Thanks,
> Ezra
> Qgis-user mailing list
