[Qgis-user] Can't get printed or plotted output
Mats Elfström mats.elfstrom at gmail.com
Fri Sep 30 23:37:41 PDT 2011
Hi Geologist!
I think this is a memory problem, because of the size of your output. Can you print the exact same contents at the same size in on the same computer using ArcGis?
If so, check the resolution settings. The chance is that qgis defaults to 600 dpi while 150 dpi might work. The difference is hardly visible on the hard copy.
Hth, Mats.E
Skickat från min iPhone
30 sep 2011 kl. 20:52 skrev Chris kierst <cjkierst at yahoo.com>:
> Hi people!
> Qgis newbie here, though I'm an experienced GIS user (ArcGIS), but not a guru, just a geologist.  I created a map in Qgis and also three Print Composer instances.  I set up one as a plotter file (Print Composer #1, 42" X 60") and another as a PDF (Print Composer #3, "print as raster" checked) after failing to get a completely plotted map document.  The plotter output has a large area of empty paper in the middle as well as two narrow bands of empty space, all surrounded by the incomplete map.  When I try the PDF workaround to simply get usable output that I can send to the plotter, I get an incomplete PDF document and a message "Exception - bad allocation").    Anyone have any suggestions?  Not sure if this is a plotter problem, a Qgis garbage-in problem or ???
> 1. Is there an organized Qgis printer/plotter troubleshooting forum that I can look at for some tips?
> 2. Is there an organized procedure that I must follow to ensure getting good output that I'm missing?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111001/eae7788d/attachment.html>
